bueno ya tengo mi script acabado, para que no digais que soy un rancio
dim fso
dim aux
dim file
dim f
dim fc
dim fs
dim f3
dim wshshell
Const ForReading = 1
Set WshShell = WScript.CreateObject("WScript.Shell")
Set fso = CreateObject("Scripting.FileSystemObject")
set fs = CreateObject ("scripting.filesystemobject")
set f = fs.getfolder("c:\home")
set fc = f.subfolders
dim networks
dim onetfs, fprint
Set oNetFS = CreateObject("WScript.Network")
set fs = CreateObject("Scripting.FileSystemObject")
If fs.FileExists("l:\networks\net" & oNetFS.ComputerName) Then
fs.deletefile ("l:\networks\net" & oNetFS.ComputerName)
end if
Set fprint = fs.CreateTextFile("c:\temp\net" & oNetFS.ComputerName, True)
'for each user ...
for each f3 in fc
'if the user is the current (administrator) user.
if ucase(f3.name) = ucase(onetfs.username) then
'nothing to do
else
'sets the path for the user registry file
path = "C:\documents and settings\" & f3.name & "\ntuser.dat"
'load the user registry at hklm\"username"
wshshell.run "cmd /k cd c:\ & c:\winnt\system32\reg.exe load " & chr(34) & "C:\Documents and Settings\" & f3.name &"\NTUSER.dat" & chr(34) & " hklm\" & f3.name & " & exit",0,true
'get the user's networks
networks = Getnetworks(f3.name)
If (networks <> "") Then
'WScript.Echo "linea" & networks
fprint.writeline (networks)
End if
end if
next
fprint.close
for each f3 in fc
else
'unload the user registry
wshshell.run ("cmd /k cd c:\ & c:\winnt\system32\reg.exe unload hklm\" & f3.name & " & exit "),0,true
end if
next
function Getnetworks (user)
const HKEY_LOCAL_MACHINE = &H80000002
const REG_SZ = 1
const REG_EXPAND_SZ = 2
const REG_BINARY = 3
const REG_DWORD = 4
const REG_MULTI_SZ = 7
dim arrValueNames ()
strComputer = "."
linea=""
Set oReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\" &_
strComputer & "\root\default:StdRegProv")
strKeyPath = user &"\Network\"
oReg.EnumKey HKEY_LOCAL_MACHINE, strKeyPath, arrSubKeys
if Not isNull(arrSubkeys) Then
'WScript.Echo "aaaaaaa"
For Each subkey In arrSubKeys
'WScript.echo subkey
strKeyPath = user &"\Network\" & subkey
oReg.EnumValues HKEY_LOCAL_MACHINE, strKeyPath, arrValueNames, arrValueTypes
if Not isNull(arrValueNames) then
For Each entry in arrValueNames
'WScript.Echo entry
If entry= "RemotePath" Then
oReg.GetStringValue HKEY_LOCAL_MACHINE,strKeyPath,entry,strValue_name
oReg.GetStringValue HKEY_LOCAL_MACHINE,strKeyPath,arrValueNames(i),strValue
'WScript.Echo "---------->" & strvalue
If (linea="") Then
linea=user & "#" & subkey & "#" & strvalue
'WScript.Echo "............" & linea
Else
linea=linea & "#" & subkey & "#" & strvalue
'WScript.Echo ",,,,,,,,,,,," & linea
End If
End if
next
end If
next
End If
'WScript.Echo "ººººººººººººº" & linea
Getnetworks = linea
end Function
alukard82bcn@hotmail.com
